• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Re: Benefits of Inventor 2012/2013 compared to Inventor PRO 11 (2007)
    07-31-2012 06:15 AM in reply to: ampster
    You have a fair point but I feel this "change for the better" is nothing but a different color paint on a rusty chair.
    Using a stopwatch, slowdowns of half a second or more exist compared to the old UI. That is not progress to me.
    Meanwhile, at release 2013 the software still fails on operations easily done on a 3 axis mill.
    ______________
    Inventor Pro 2012
    Vault Pro 2012
    Please use plain text.
    *Pro
    jletcher
    07-31-2012 08:52 AM in reply to: Rich.O.3d
    richos69 said :
    i doubt that you run 3000 commands a day more like 200 - 300 max
    when it was the old classic interface 3000 was nothing but yeah on this new interface I'm down to 200
    and if you only do 200 to 300 old or new interface to me you are not working at my speed and is why you like the new interface makes you look fast.
    1 click = 0.1 secs
    you must have a very small monitor. mine is 32" it takes me that long just to look up at the new interface when with the old the panel with the commands was right next to my mouse in the graphics window not docked so I only needed to move mouse very little now with new interface its like miles, move pointeer lift up mouse pull back mouse put mouse down move pointer closer to interface repeat till I reach interface.  so your time way off..
    The projects we design these days with 10 to 20 Engineers and 10 to 20 drafters take 1/8th of the time it used to take 50 engineers and 100 drafters on drawing machines and slide rules.
    Has nothing to do with Inventor. But change of times.
    the whole extra click story was invented by lazy drafters trying to come up with excuses for there poor performance
    I don't see this being true at all. when you add clicks to the same command it will take longer, when I have to find the tab a command is under may have a brain fart and click 4 tabs before the light goes off. never had that issue with the old interface. when I was done with sketch it put me on model all by itself it was cool and when I demo that feature the crowd goes wild because they no long have to find it. and trust me I worked with alot of engineers old and young I could show you ten times where it is the next day you will ask again. In the old there it was for you..
    for every extra click in a new release, there are usually a myriad of other time saving improvments that actually impact on productivity in a positive way
    Well I'm still looking for the improvments from the extra click. oh I found it the new picture on the box was an improvment.
    Here new thing for you.
    I just design this new keyboard the buttons press 5 times faster but I moved the keys around but don't worry you will get use to it.. the "F" key are where the numbers were. the "A" key is now in the "M" key location The "G" key is now the "TAB" key the "TAB" key is now the "DELETE" key. and you have to hit enter 3 times before it enters.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Doug_DuPont
    07-31-2012 11:03 AM in reply to: jletcher
    I blame that dam mini toolbar. I hate that thing. Plus you can not turn it off and just use the dialog windows.
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    *Pro
    jletcher
    07-31-2012 11:28 AM in reply to: Doug_DuPont
    yeah I dislike those too but I see in near future 2014 2015 the old dialog will go away then we will have to deal with that mini  crap.... But not me I will not update again 2012 will be as far as I go as long as I can anyway.
     Don't like the changes that they are making to me they are not very good..
    Sad too  as I loved Inventor they use to call my Inventor Jim, now not so when asked about Inventor I just act as if I never herd them..
    :smileysad:
    James Letcher
    Valued Mentor
    Rich.O.3d
    07-31-2012 03:50 PM in reply to: jletcher
    what a wally
    while you are counting clicks, I am producing MASSIVE amounts of work (I look fast because I understand the engineering and have techniques that allow me to leverage the power of the program nothing to do with the interface) using the new tools that have been offered to me by Inventor, plant3d, asd, revit, navisworks,...the list goes on
    while your plowing through the old classic menus, ive RMB's or ribboned (including the extra clicks) and have moved on to another part of the design.
    stop trying to quantify something that has little to no relation to the outcome...better designs delivered at a lower overall cost. The cost of 'clicking' on a project is 1/100000 of the cost of the project.
    We are producing more and more accurate design data at a lower overall cost than ever before in history
    try loading inventor 7 and produce project documentation similar to what you are producing on Inventor 2013, I guarantee you will be counting clicks till the cows come home.
    Home many clicks did it take you to respond? did you count them, did they have an impact on your deliverables????
    Im sick of this "it takes me an extra click to do a command therefore the new software is flawed" story
    I judge my productivity on total output, not on how long a certain task takes. Thats one of the reasons why Im a Senior Designer with one of the biggest Multinational EPCM's on the Planet
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Valued Mentor
    07-31-2012 07:10 PM in reply to: Vlad.Makarov
    For the OP this is a great example of being carefull with who you listen to.  You will find that the views of an employee who is paid the same each week no matter what and is given the software to use for free differ greatly from the self employed that pay their own expenses and get paid based solely on productivity.  Same goes for educators and trainers.  Problems dont cost them money, they actualy give them something to teach and consult about.
    I once worked for a big company and had a fancy title and a six figure salary and I can assure you that my views about software are very different now that I am a business owner.  Its now my time and my money and every problem makes a difference.  The days of saying oh well, who cares, just book it to re-work are long gone.  I look at the cost of subscription compared to what I got and am glad I didnt pay it on 20 seats.  I also find the bigger the company is the less likely they are to ever consider changing software.  They becoome brand loyal because they are afraid of problems that change may cause with old data.
    But for you (the OP) you are making a decision about spending someone elses money, so since 2007 is so out of date treat this as a new software purchase and look at all the options and make the best decision for your boss based on what you need the software to do.  They have all come a long way since 2007.
