• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Bending round bar
    08-30-2011 06:21 AM in reply to: chrisw01a
    chrisw01a wrote:
    So it is.  I got it to bend.  Is there a way to "flatten" that out now for placement on a drawing showing the full length of the part then?
    Thanks alot.
    Use two parts. one flat part, then derive the flat part and apply the bend to it.
    Mike
    Please use plain text.
    Valued Mentor
    coreyparks
    08-30-2011 07:22 AM in reply to: Mike_Maenpaa
    For most things I just use a sheet metal part that is .250 thk. x .2501 wide and add .250 fillets to all edges.  Leaves a tiny .0001 flat but that causes me no problem for most of the things I do.
    Please mark this response "Accept as solution" if it answers your question.
    Corey Parks
    IV2012 Factory Design Suite Ultimate 64bit
    Includes: Inventor Professional, AutoCAD Architecture & Navisworks Manage
    Windows 7 64 bit- Synergis Adept document management software
    16gb RAM --- Nvidia Quadro 4000 2gb
    Active Member
    adavis
    09-15-2011 10:26 AM in reply to: chrisw01a
    Hello you previously replied to a bending problem that I was concerned about.  On your reply you sent an attachment that I can not veiw.  The soild bar is turned off or blacked out and my co-worker  and I have tried and we cannot seem to  make it visable. The other person responding to my inquiry seemed to able to view it.  If you could please resend the attachment explaining how to bend a rod/round bar it would be greatly appreciated.
    *Pro
    09-15-2011 10:44 AM in reply to: adavis
    I'm guessing that you need to pull the End Of Part back down to the bottom of the browser.  Saving it with the EOP at the top of the tree makes all the geometry invisible, but also makes the file size much smaller for posting to the forum.
    *Expert Elite*
    blair
    09-15-2011 10:45 AM in reply to: adavis
    Open the file within Inventor, in the Browser Bar, drag the EOP marker (looks like a Stop-Sign) down to the bottom fo the features within the Browser.
    Makes file smaller for up & down loading.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Valued Contributor
    In your browser window where all the features and such are listed, grab the "end of part" icon and drag it down to the bottom this will enable the features.
    *Expert Elite*
    09-15-2011 11:12 AM in reply to: adavis
    FYI - Saving with the EOP in a rolled up state significantly reduces the file size.
