Bend Table Problem
Bend Table Problem
Bend Table Problem
Guys,
Please bend part attached. And original txt file from client
When I make a 90 degree bend on a model with 10mm thickness I get the following when I try to make flat patteren:
Create Flat Pattern (ShapeManager): problems encountered while executing this command.
Part1: Warnings occurred during update
Part1 (Flat Pattern): Warnings occurred during update
Definition1: Problems occurred while building this ASMFlatPattern
Error querying the Bend Table. The angle or radius are outside the table boundaries. The input values were: Thickness: [10,000000], Angle: [90,000000], Inner Radius [10,000000].
I have radius set to 15mm don't I?
What am I doing wrong here?
Michael
jletcher
You need to change either the radius in your part or your bend table.
Your bend table has a 15mm radius but your model has a 10mm radius.
This is the issue change one or the otheer and you are good to go..
Or just make another column with a 10mm radius.
