- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Guys,
Please bend part attached. And original txt file from client
When I make a 90 degree bend on a model with 10mm thickness I get the following when I try to make flat patteren:
Create Flat Pattern (ShapeManager): problems encountered while executing this command.
Part1: Warnings occurred during update
Part1 (Flat Pattern): Warnings occurred during update
Definition1: Problems occurred while building this ASMFlatPattern
Error querying the Bend Table. The angle or radius are outside the table boundaries. The input values were: Thickness: [10,000000], Angle: [90,000000], Inner Radius [10,000000].
I have radius set to 15mm don't I?
What am I doing wrong here?
Michael
