• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    karthur1
    Re: Benchmark for Autodesk Inventor 2012
    11-04-2011 09:08 AM in reply to: prusas
    Here is my results for the 1000.iam test.  I compared 2011 and 2012.  Same machine.. similar application option settings.  If 15 is the refresh rate we are after, 2011 would do about 650 parts, 2012 is down to 525. A drop of about 20%.
    Please use plain text.
    11-04-2011 12:10 PM in reply to: karthur1
    ah ha.. Got it.. (Display Silhouettes should be turned off)
    400 parts 15.2Hz refresh rate at 1920 x 1080 resolution. (quality hardware mode)
    400 parts 15.8Hz refresh rate at 1920 x 1080 resolution. (performance hardware mode)
    400 parts 15.95Hz refresh rate at 1920 x 1080 resolution (compatibility hardware mode)
     I had "display silhouettes" turned on (default is off). As soon as I turned it off I went from 200 to 400 parts at 15Hz..
    :smileyvery-happy:
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Distinguished Contributor
    11-04-2011 12:46 PM in reply to: mcgyvr
    Silhouettes are turned on in both 2010 and 2012 in the results I show below.
    IV2012 is still a dog when compared to IV2012 D3D 10.
    However I did 500 parts with sihlouettes off in IV 2012, here are the quick results:
    Quality, 500 parts, 1920 x 1200  16.39 Hz
    Performance, 500 parts, 1920 x 1200 16.67 Hz
    Compatability, 500 Parts, 1920 x 1200 16.95 Hz.
    Also, I have dual 1920 x 1200 displays, not sure how that affects results since the only part of Inventor on the second monitor is the browser bar.
    11-04-2011 12:58 PM in reply to: mcgyvr
    ... Just to add to the numbers
    Hits 15 Hz at 400 parts, although I noticed that if zoomed in the Hz went up.  Evens out at 15-ish after the entire assembly is in view and spinning.  Zooming out further doesn't change anything.
    my vital statistics...
    Windows 7 64 bit
    Intel® Core™ i7 CPU 860 @ 2.8GHz; RAM 8Gb
    Hard drive (300 GB)
    NVIDIA Quadro 4000; Samsung SyncMaster 2343 - 2048 x 1142
    Valued Contributor
    prusas
    11-05-2011 03:09 AM in reply to: vandargo
    Summary of interim results
    Windows 7 64 bit
    Intel® Core™ i7 CPU X 990 @ 3,9; RAM 12Gb x 1600
    OCZ-Vertex 4 SSD (119.24GB)
    Asus NVIDIA GeForce GTX 580; PLE2607WS 1920x1200
    Valued Contributor
    prusas
    11-05-2011 07:35 AM in reply to: prusas
    During the summary, there was a suspicion that there may be misread the data. Therefore, if you have the opportunity, please submit the test data in a form.
    Windows 7 64 bit
    Active Contributor
    11-05-2011 08:34 AM in reply to: prusas
    And that test is more reliable? "Inventor 6 bench" is like a kinder for us...
    _______________________________________________________
    Windows7 64b; GIGABYTE EX58-UD5; Intel Core i7 920 (2.66GHz)
    DDR3 3x2GB Kingston, HD ST 750GB+320GB
    NVIDIA Quadro FX1800 (1680x1050) + SpacePilot PRO
    Valued Contributor
    prusas
    11-05-2011 09:43 AM in reply to: malenki
    300 part -
    Shaded
    manual                    32Hz
    Inventor 6 bench    36,5Hz
    Hiden
    manual                    4,9Hz
    Inventor 6 bench    8,8Hz
     Wireframe
    manual                    27Hz
    Inventor 6 bench    26,6Hz
    but "Inventor 6 bench" exactly the same is not valid for all users
    Windows 7 64 bit
    Valued Contributor
    prusas
    11-05-2011 11:09 AM in reply to: prusas
    interesting coincidences
    Windows 7 64 bit
    Valued Contributor
    mbenoy
    11-05-2011 11:19 AM in reply to: karthur1
    I ran my home PC to see how it handled the same.
    I got approx. 460 parts (shaded with edges) at 15Mhz.
    System is the following
    AMD Athlon II X3 445 3.11Ghz
    8GB DDR1600
    NVIDIA GTX 560 Superclocked 2GB
    1680x1050 Resolution
    Windows 7 x64
    Michael Benoy
    Designer
    Scott Safety
    Inventor 2012 Pro, Windows 7, 64bit
    Intel® Xeon® Processor W3580 (8M Cache, 3.33 GHz)
    12 GB DDR3, NVIDIA Quadro FX 3800
