Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Benchmark for Autodesk Inventor 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Autodesk inventor 2012 has worked exclusively on Direct3D. At the moment, there is no single test that is likely to correctly identify performance hardware.The results of such tests as Cinebench, 3DMark, SPECviewperf - untrue. But the need to determine the real performance of video cards is growing. According to this offer on their own to determine the performance of different video cards. For the test we will use the internal mechanism of Autodesk inventor 2012 definition of refresh rate.
One benchmark test that you can perform is to run the Post Statistics.
This requires an understanding of registry editing.
Go Start>Run & type “regedit”. Click OK & navigate to this branch: HKEY_CURRENT_USER\Software\Autodesk\Inventor\Regis
The next time Inventor is run, a small information box will appear at the bottom of your screen.
We twist the assembly . Pattern editing in the assembly "1000.iam", we change the number of parts in the assembly until the refresh rate will be equal to 15 Hz. This is the minimum, and psychologically comfortable refresh rate.We work exclusively in the factory settings
The results report in the next volume:
1. The operating system and its capacity
2. Processor
3. RAM
4. Video card
5. Number of parts with assembly at a refresh rate of 15Hz.
Intel® Core™ i7 CPU X 990 @ 3,9; RAM 12Gb x 1600
OCZ-Vertex 4 SSD (119.24GB)
Asus NVIDIA GeForce GTX 580; PLE2607WS 1920x1200
Re: Benchmark for Autodesk Inventor 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Windows 7 64 bit
Intel Core i7-x990
Nvidia Geforce GTX 580
RAM 12Gb
Refresh rate 300 part -15Hz
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Windows 7 64 bit
Intel core duo L7500
Mobile Intel 965 express
RAM 4Gb
Refresh rate 20 part -15Hz
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Interesting..
Results (shaded with edges)
Refresh rate 200 parts - 15.63Hz
Results (wireframe)
Refresh rate 400 parts - 16.13Hz
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
500 parts = 15.8Hz
600 parts = 13.8Hz
Interestingly, if I change the first pattern from a 10x10 to 5x5 and the second pattern to 5, 125 parts = 11.7Hz
All done as "shaded with edges".
Designer
Scott Safety
Inventor 2012 Pro, Windows 7, 64bit
Intel® Xeon® Processor W3580 (8M Cache, 3.33 GHz)
12 GB DDR3, NVIDIA Quadro FX 3800
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
wow.. this has got me curious.. mbenoy got some excellent results.. Is it the xeon or the quadro or the velociraptor or all combined.. We need more results.. Come people.. Do it.. Only takes a few minutes.
Windows 7 64 bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If interested, while rotating:
CPU Usage = 50%
GPU Clock = 45%
GPU Memory Usage = 5% (of 1GB)
If you take a look at each of the cores and how it breaks down to get the 50%. Obviously, the CPU cores jump all over the place while making a total of 50%. The following are very rough estimates of the ranges of each core during that time:
Core 1 = 80-95%
Core 2 = 70-85%
Core 3 = 8-30%
Core 4 = 30-55%
Designer
Scott Safety
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't have time to try this at work tomorrow, but I'm curious-- does the pixel count of the display have an effect on this benchmark? My laptop screen is 1680 x 1050, but the screen I mostly use it with on my desk is 2560 x 1600, 2-1/3 times the number of pixels. I suspect that the GPU works harder to calculate more pixels, so these results will have to be related to pixel count, I think.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For the test results add one more parameter - the screen resolution.
Intel core i7-x990 - 1900x1200 load: CPU- 12%; GPU-9%; GPU memory 64MB.
Intel duo core L7500 - 1024x768
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My results with 15Hz: slightly above 500 part (see attachment)
Windows7 64b; GIGABYTE EX58-UD5; Intel Core i7 920 (2.66GHz)
DDR3 3x2GB Kingston, HD ST 750GB+320GB
NVIDIA Quadro FX1800 (1680x1050) + SpacePilot PRO
