• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Beam/colmn Calculotor: Changing the angle of a distributed load
    243 Views, 5 Replies
    08-20-2012 09:38 AM
    I am using beam/column calculator in the frame generator in inventor 2010 suite.
    I have a beam being used for a flight of stairs it is positioned 40 deg above the 'floor' or my xy plane in my assembly.
    I want to place a distributed load acting as if there were several people stading on the stairs at one time so in the direction of the z axis of my assembly.
    The problem I am having is I try to change the angle of the distributed load but it only allows me to change the x and y components of the load. You can see this in the screenshots i took.
    Is there a way I can:
    a) change the angle of the laod in the Z directions
    or
    b) change the cordinates in beam itself so the x axis is along the length of the beam instead of the z axis.
    I have tried adding a UCS to the beam part but it still wants to choose the length of the beam as the z axis.
    Any help would be greatly appreciated.
    Matt
    Please use plain text.
    *Expert Elite*
    Re: Beam/colmn Calculotor: Changing the angle of a distributed load
    08-20-2012 01:52 PM in reply to: vogelzmr
    I'm not sure what all of the options are in the beam calculator, but you could do this by splitting your load into a Y component and an axial load component (Z component).  So in effect, you will have two loads applied.  One for the vertical Y component of the total load, and an axial load for the Z component.  Does that make sense?
    *Expert Elite*
    blair
    08-20-2012 02:09 PM in reply to: vogelzmr
    Select/Check the Vector box in the Load dialogue box. You can then enter in your load vectors, or create a work axis and use it for load direction. I believe you can even use a Work-Axis to define the load direction (still need to "Check") the vector box.
    Sorry, I was thinking of either analysis in model or frame-gen.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Member
    08-21-2012 10:06 AM in reply to: blair
    There is no vector box to 'check' i think that is a feature of the stress analysis found in the 2010 pro version, which i unfortunately do not have. I am using the beam/column calculator found in the frame generator feature of the 2010 suite version.
    Member
    08-21-2012 10:08 AM in reply to: cwhetten
    This will work, i just was hoping to avoid breaking up my applied load into axial and shearing loads, i know that is lazy of me, thanks for the help!
    Matt
    Valued Mentor
    jdkriek
    08-21-2012 01:31 PM in reply to: vogelzmr
    Good information, thanks for sharing.
    Jonathan D. Kriek
    Inventor Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
