• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Batch "save copy as" is there a way to do this
    261 Views, 8 Replies
    05-19-2009 02:56 PM
    So I have a client who wants step files for each of the 85 components in our skid design so they can run the data through their plasma cutter.
    Is there a way to batch open and save copy as for all these parts instead of me opening and saving each part out one at a time?
    IV 2010 SP3
    Please use plain text.
    Re: Batch "save copy as" is there a way to do this
    05-19-2009 03:24 PM in reply to: FritscheDesign
    Look at Task Scheduler. I'm at home at the moment, so I can't say that that exact function is available though....
    *Hugh Henderson \(Autodesk\)
    05-19-2009 03:50 PM in reply to: FritscheDesign
    Hi fritschedisgn,
       "Copy Design" in Vault may be the
    answer you're looking for.
    -Hugh
    **Master
    05-19-2009 04:29 PM in reply to: FritscheDesign
    as Hall said, use Task Scheduler
    Programs > Autodesk > Autodesk Inventor 20** > Tools > Task Scheduler
    Use the Export Files task to translate:
    Autodesk Inventor (*.ipt) and assembly (*.iam) files to:
    IGES files (*.igs, *.ige, *.iges) (Default output is *.igs.)
    STEP files (*.stp, *.ste, *.step)
    DWG (*.dwg)
    SAT files (*.sat)
    JT files (*.jt)
    Parasolid files (binary (*.x_b), text (*.x_t))
    Pro/ENGINEER files (Granite (*.g), Neutral (*.neu))
    CATIA V5 (*.CATPart (part), *.CATProduct (product))
    STL (*.stl)
    05-20-2009 08:06 AM in reply to: FritscheDesign
    I tried the Task Scheduler but I was unable to find where to change the format?
    IV 2010 SP3
    *Expert Elite*
    karthur1
    05-20-2009 08:16 AM in reply to: FritscheDesign
    In the export files dialog, click on the output file name column to change format.
    Active Contributor
    darnold
    12-20-2012 07:24 AM in reply to: karthur1
    Does translating the assembly file that way result in individual translated files? is there any way to select the output for multiple files all at once or do they have to be selected individually? I have hundreds of files that I have to translate out for other systems.
    *Expert Elite*
    blair
    12-20-2012 08:51 AM in reply to: darnold
    I might do a Pack-and-Go to get out the files I need if they belong to a specific assembly. Get them to a separate directory with a Project file. Then run the Task Scheduler for that folder/project.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Contributor
    darnold
    12-20-2012 10:42 AM in reply to: blair
    I see, the "Folder" choice doesn't allow a destination directory, hence the Pack and go. Makes sense. Ill try it ASAP and let you know.
