Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Basic folding/be nding of a sheet metal.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I want to bend/fold this piece over a specific profile. Could somebody point me in a direction where to start? There are too many tools for bending a sheet metal and I just don´t know where to start. I searched the web and this forum but there are too many options. Also when I create the flat pattern, it should be precise with a difference max +/-5mm.
I thought I could use contour flange. Usualy it works. But only when it´s a simple rectangle. But not on this part.
If you know about some tutorials I would be very thankfull.
I work with Inventor 2011.
Re: Basic folding/be nding of a sheet metal.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should almost never Fold a part.
Use Contoured Flange. Always model as finished part.
Attach your ipt file with sketch here.
Could you use some other color for the dimensions? It is difficult to read those dimensions.
Your sketch should look like this (but with the dimensions - you won't need all of the dimensions since some are redundant). you only need open profile (no thickeness - Inventor will add the thickness).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I´m sorry, I forgot to attach the ipt file. Here again.
Also one more question...how do I finish the part?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I still haven´t figured it out. Problem is when I use contoured flange, the shape of the part won´t be the same. Also when I unfold the part, it´s 60mm longer.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Make sure your sheet metal rules are set for the proper thickness.
Inventor 2012 SP1
Vault Pro 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It´s set to 15mm. But why doesn´t the final part look like I have draw it? See the attachment so we understand eachother.
PS: I can´t open your file.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would guess that you made your cuts to the flat pattern.
All modifications to the part should be done on the model, not the flat pattern.
See tha attached part.
Inventor 2012 SP1
Vault Pro 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You´re right. At first I draw the part and then I use contour flange. I thought when I do it after, the flat pattern won´t be the same. Thank you very much mpatchus, that helped me. ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mpatchus wrote:I would guess that you made your cuts to the flat pattern.
Did you attach the correct file? That one doesn't look correct? (not like the image you posted - looks like the same file you originally posted)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You are correct JD... thanks.. here is the correct file.
Inventor 2012 SP1
Vault Pro 2013
