• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Basic folding/bending of a sheet metal.
    428 Views, 9 Replies
    01-24-2013 07:31 AM
    I want to bend/fold this piece over a specific profile. Could somebody point me in a direction where to start? There are too many tools for bending a sheet metal and I just don´t know where to start. I searched the web and this forum but there are too many options. Also when I create the flat pattern, it should be precise with a difference max +/-5mm.
    I thought I could use contour flange. Usualy it works. But only when it´s a simple rectangle. But not on this part.
    If you know about some tutorials I would be very thankfull.
    I work with Inventor 2011.
    Please use plain text.
    Re: Basic folding/bending of a sheet metal.
    01-24-2013 07:35 AM in reply to: maros.mmo
    You should almost never Fold a part.
    Use Contoured Flange.  Always model as finished part.
    Attach your ipt file with sketch here.
    Could you use some other color for the dimensions?  It is difficult to read those dimensions.
    Your sketch should look like this (but with the dimensions - you won't need all of the dimensions since some are redundant). you only need open profile (no thickeness - Inventor will add the thickness).
    Member
    01-24-2013 11:04 PM in reply to: maros.mmo
    I´m sorry, I forgot to attach the ipt file. Here again.
    Also one more question...how do I finish the part?
    Member
    01-29-2013 03:57 AM in reply to: maros.mmo
    I still haven´t figured it out. Problem is when I use contoured flange, the shape of the part won´t be the same. Also when I unfold the part, it´s 60mm longer.
    Valued Mentor
    mpatchus
    01-29-2013 04:20 AM in reply to: maros.mmo
    Make sure your sheet metal rules are set for the proper thickness.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Member
    01-29-2013 04:49 AM in reply to: mpatchus
    It´s set to 15mm. But why doesn´t the final part look like I have draw it? See the attachment so we understand eachother.
    PS: I can´t open your file.
    Valued Mentor
    mpatchus
    01-29-2013 05:04 AM in reply to: maros.mmo
    I would guess that you made your cuts to the flat pattern.
    All modifications to the part should be done on the model, not the flat pattern.
    See tha attached part.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Member
    01-29-2013 05:27 AM in reply to: mpatchus
    You´re right. At first I draw the part and then I use contour flange. I thought when I do it after, the flat pattern won´t be the same. Thank you very much mpatchus, that helped me. :smileyhappy:
    Did you attach the correct file?  That one doesn't look correct? (not like the image you posted - looks like the same file you originally posted)
    Valued Mentor
    mpatchus
    01-29-2013 07:20 AM in reply to: JDMather
    You are correct JD... thanks.. here is the correct file.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
