• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Ballistic Knife Variation Help
    216 Views, 1 Replies
    08-07-2012 09:31 PM
    I am a novice when it comes to inventor and i am trying to make my spin on a ballistic knife. instead of the classic trigger mechanism used i am using a peg/slot mechanism to fire. i need a peg less than .9 in in diameter that will slide in the "L" hole i made in the knife projectile. I would enjoy someone who could attach the peg so i can assemble it. Here are the files so you can mess with them. The cap attaches to the bottom of the handle. thanks in advance.
    Please use plain text.
    *Expert Elite*
    Re: Ballistic Knife Variation Help
    08-08-2012 06:58 AM in reply to: bakeraustin47
    Many of your sketches are unconstrained and no dimensions?
    What is the tap drill size for a 1.125-7 thread?
    I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    Once you have the parts dimensioned I can probably help out.
