• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Bad quality saving from IV6 to AutoCAD
    35 Views, 3 Replies
    11-25-2002 02:32 AM
    I am new to drawings on Inventor so this might be something simple I just don't know about. Is there any way to set up the line widths in Inventor for exporting to AutoCAD. When I export something all the lines are at different pin widths and even after I change them to default in AutoCAD, they still look huge on the screen.
    Please use plain text.
    *Parks, Corey
    Re: Bad quality saving from IV6 to AutoCAD
    11-25-2002 02:51 AM in reply to: JasonA1234
    When you are in Autocad just turn off the line
    weight display.  On Acad 2000 there are buttons along the bottom of the
    screen, toggle the "LWT" button off and this should fix the
    problem.
    Remove "22" in address to email me
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    huge on the screen.
    *mpower
    11-25-2002 04:05 AM in reply to: JasonA1234
    If you are trying to control the line width by
    layer in AutoCAD, make sure that the lineweight control for each line is set to
    ByLayer.
    I
    huge on the screen.
    *R, Kevin
    11-25-2002 06:40 AM in reply to: JasonA1234
    The is also a LWT global scale adjustment in
    the autocad options which controls how heavy the lineweights appear
    onscreen
    I
    huge on the screen.
