• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    mcrump28210
    Background Color
    569 Views, 4 Replies
    09-06-2012 09:27 AM
    I need to turn the assembly background pure white for illustrative purposes.  Is this possible in Inventor 2013
    Michael Crump
    AutoCAD 2013
    Inventor 2013
    Windows Pro 7 x64
    Asus Sabertooth X58
    Intel Core i7 960 @ 3.2 GHz
    24 GB ram
    Please use plain text.
    MariaManuela
    Re: Background Color
    09-06-2012 09:31 AM in reply to: mcrump28210
    Hi
    Absolutely yes.
    Tools \ Application Options \ Color... then select Presentation shceme with 1 color background
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    Active Contributor
    mcrump28210
    09-06-2012 09:38 AM in reply to: MariaManuela
    Perfect!  Thanks so much!!
    Michael Crump
    AutoCAD 2013
    Inventor 2013
    Windows Pro 7 x64
    Asus Sabertooth X58
    24 GB ram
    MariaManuela
    09-06-2012 09:48 AM in reply to: mcrump28210
    In addiction you can install the Autodesk plugin called Screen Shot for Inventor.
    About:
    Screenshot can be used with Inventor to simplify image capture of the entire Inventor application window, the graphics view of documents open within Inventor, or parts of the graphics screen. You can also remap the background to white and the foreground to black, and convert the entire image to grey scale, as well as sending the captured image directly to a printer. This plug-in was first published as an ADN Plugin of the Month: http://labs.autodesk.com/utilities/ADN_plugins. The plug-in has been provided with the complete source code needed to build the application, with the intention of encouraging users of Autodesk software to use programming to tailor the products they use to their specific business needs.
    http://apps.exchange.autodesk.com/INVNTOR/Detail/Index?id=autodesk.appstore.exchange.autodesk.com%3a...
    Maria Manuela Pinho
    Curtis_Waguespack
    09-06-2012 11:23 AM in reply to: mcrump28210
    Hi mcrump28210,
    Here's another tip on the subject:
    http://inventortrenches.blogspot.com/2012/09/inventor-background-color-as-white.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
