• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    BOM parts and assemblies are read only
    290 Views, 9 Replies
    10-30-2008 09:07 AM
    I have some BOM parts and an assembly that are read only and I need to be able to enter information in the bill of materials under the status column and the comments column. The BOM parts are i-parts and the assembly is an i-assembly. Is there a way to set them to read or is this a limitation?
    Please use plain text.
    *Dennis Jeffrey
    Re: BOM parts and assemblies are read only
    10-30-2008 09:21 AM in reply to: janitor1
    Are they located in a library folder or possibly copied from a
    CD/DVD?  Check prperties on the parts and make sure they are not flagged
    read only in Windows.
    Dennis Jeffrey, Autodesk Inventor Certified
    Expert
    Autodesk Manufacturing Implementation Certified
    Expert.
    Instructor/Author/Sr. App Engr.
    AIP 2008 SP2, AIP 2009-SP1
    PcCillin AV
    HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
    XP
    Pro SP2, Windows XP Silver Theme
    href="http://teknigroup.com">http://teknigroup.com
    Valued Contributor
    10-30-2008 09:47 AM in reply to: janitor1
    Not in a library folder or copied.
    Not flagged read only in windows.
    Common factor is i-parts and i-assembly.
    Valued Contributor
    10-31-2008 05:30 AM in reply to: janitor1
    Deleted the i-assembly table to make it into a regular assembly. Can now change properties in BOM. Apparently cannot assign properties to an i-assembly or i-part.
    Member
    11-20-2012 08:50 AM in reply to: janitor1
    I am having the same problem. I am using Inventor Professional 2012 and I have created complex iparts and iassemblies and I am not able to change the BOM structure of the parts simply because they are intelligent.  I require the tables and features that the iparts and iassemblies can create but they are coming up read only and can not modify the BOM information. Is there a way to change the read only aspect of an ipart or iassembly?
    *Expert Elite*
    cbenner
    11-20-2012 11:32 AM in reply to: robert.henderson
    Are you using Vault?  Are any of these parts Content Center parts?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Member
    11-20-2012 11:45 AM in reply to: cbenner
    I am not using Vault, all files are on my local server.  Also all parts and assemblies have been created from nothing.  I work in the Rail Industry, for example one of my iassemblies is a bungalow.  This bungalow has 6 options, these options change the physical size of the bungalow, this bungalow comes with receptacles, lights, light switch(es), exhaust fan, heater, thermostats, shelves, and a distribution panel.  This will show up as a single item on my BOM, but there is a lot of intelligence (equipment moves or gets added depending on the selection) within my assembly and I can not change anything on my BOM because its coming up as read only.  This particular iassembly contains parts, iparts, and iassemblies all of which I have created since my content is very unique.  Everything works as I want, except the BOM.
    *Expert Elite*
    cbenner
    11-20-2012 12:02 PM in reply to: robert.henderson
    Any chance of posting the assembly or any of the files?
    ChrisB
    Member
    11-20-2012 12:09 PM in reply to: cbenner
    I've attached the bungalow that would be set up in the master BOM as a single item. This iassembly will end up in a template which I am setting up.
    Member
    11-21-2012 07:25 AM in reply to: robert.henderson
    Sorry about that,
    I did not pack and go my assembly.  I know why its read only, basically because the bungalow assembly has options since its intelligent that information could change when you put in into another assembly. I can put properties into my table such as the description, however I do not see an option to put my custom iproperties in the table, that’s where I have hit the road block at this point.
    The bungalow has been posted on our FTP site, details noted below. Using Internet Explorer access through address: https://www.hmmftp.com/
    Username=ro6251
    Password=5ONSUEkV
    * Data Stored here will be purged on Sat Nov 24 10:03:02 EST 2012.
