• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    BOM / Parts List Question
    322 Views, 6 Replies
    06-07-2012 12:30 PM
    In my parts lists the length (81 inches) is displayed as 81 in.  How do I make it so it displays as 81 without the "in" suffix?
    Also, is there a way to enter a formula like in excel so I can divide the sum by 12 then ROUNDUP to the nearest whole number?
    Our system is counting the materials we use to the nearest foot and I'd rather export it to excel already converted.
    Thanks!
    Steve
    Inventor 2012
    Steve Frey
    Inventor 2013
    Windows 7 Professional 64-bit SP1
    HP EliteBook 8470w
    Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
    Memory: 16 GB
    AMD FirePro M2000
    3D Connexion SpacePilot
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: BOM / Parts List Question
    06-07-2012 12:50 PM in reply to: SteveFrey
    Steve,
    Edit the parts list and on the QTY column select format column.
    Try editing the units here.
    As far as the forumula I really don't know.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Valued Contributor
    schae235
    06-07-2012 12:57 PM in reply to: Cadmanto
    I am not sure if you would want to do this but there is a formula in ilogic to round a number to the next highest whole number.  I am 98% sure that it is "Ceil()"
    Not sure if you would want to have an ilogic code to save the parameter using Ceil() and then put that parameter in the BOM?
    maybe using
     "ThisBOM.OverrideQuantity("Model Data", partNumber,quantity)
    Example:
    ftQty=Ceil(inQty/12)
    ThisBOM.OverrideQuantity("Model Data", partNumber, ftQty)
    Of course  fixing the "Model Data" and the partNumber
    INV 2012 SP1
    Windows 7 64 Bit
    ATI FirePro V5800
    14.0 GB RAM
    06-07-2012 01:36 PM in reply to: Cadmanto
    Thanks!
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    06-07-2012 01:37 PM in reply to: schae235
    I haven't used iLogic so I'm afraind this won't work for me.  Thanks.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    Product Support
    06-13-2012 12:02 PM in reply to: SteveFrey
    The iLogic approach is a good option but if you’re not comfortable in it there are two other options I can think of: the first is to allow Inventor to round to the nearest whole value – if you don’t care about rounding down. See “Approach_1_A” and “Approach_1_B”.
    In option 2 you can use the “ceil” function to round up to the next highest integer but it’s expected to be unitless (using ceil) so you need to use isolate;unit;ul like “ceil(isolate(LG;in;ul) / 12 ul)” as pictured. This will make sure that, if the length is 73” it won’t round down to 6’ but round to the next highest foot value (7). Please see the attached images (“Approach_2_A” and “Approach_2_B”).
    In either case, if you don’t want to show the units, you deselect “units string”.
    Please mark this as resolved if it answers your questions and resolves this. Thank you.
    Daren Lawrence
    Product Support Specialist
    MFG Support - Inventor
    Autodesk, Inc.
    http://beinginventive.typepad.com/being-inventive/
    Product Support
    06-13-2012 12:03 PM in reply to: Daren.Lawrence
    And, due to the 3 attachment limit, here's "Approach_2_B".
    Daren Lawrence
    Autodesk, Inc.
