• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Axis display glitch
    182 Views, 3 Replies
    10-18-2012 04:02 PM
    The small red-green-blue XYZ axes that usually sit in the corner of the assembly area display are stuck in the middle of the window and won't go away (see attached screenshot).  They rotate as I change the viewing angle, but they are much too large and will not move.  This problem persists with any part or assembly file I open.
    On a seemingly related note, the small yellow circles that usually bound the ends and corners of work axes and work planes are also greatly enlarged as well as very pixelated (see 2nd screenshot).
    This became an issue after I tried exporting a .jpg.  The software froze up, and when I restarted it, the axes were messed up.
    Please use plain text.
    Member
    Re: Axis display glitch
    10-18-2012 04:30 PM in reply to: mldion1
    Some with the vendor we bought from helped me out with this.  Basically some of the display settings changed when the program crashed.  Tools-->Application options-->General tab: the "Annotation scale" should be set to 1, but was changed to a large number outside the permitted scale.  Also, under the Application options-->Sketch tab, the "Constraint and DOF symbol scale" was also set to a large number outside the scale, so I reset it to 1.
    Cadmanto
    10-19-2012 06:19 AM in reply to: mldion1
    Did you  try restarting your PC?
    Are all of your graphics drivers the latest and most current?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Member
    10-19-2012 09:38 AM in reply to: Cadmanto
    Thanks, no, but someone helped me resolve the issue (see my reply to my own post above).
