• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Automatic idw filename
    257 Views, 8 Replies
    01-17-2013 04:53 AM
    I've recently changed idw template and since then when I put part view into new draft the file name don't change into source file name.
    In standard template, when I save the .idw file it automaticly propose name that is equal to source .ipt and .iam.
    Where is the problem? Why when I'm saving files it won't propose file name the same as the source ipt file name?
    Please use plain text.
    Distinguished Contributor
    Mason-Paul
    Re: Automatic idw filename
    01-17-2013 06:29 AM in reply to: Rzeszot
    Have you got your default  template to the correct location? This should be the same location as the default templates, as shown in attached "new template. jpg" inch is the new template in this case, as shown
    You will need to make sure that the iproperties are entered in the source file as these are used to fill in the automated text entries in your template if these are blank then the corresponding part of you title-block will be blank
    You also need to make sure that you have selected the correct file name as there are several options in the definition table that can affect you template. See the attached(Idw Filename template.jpg)  for IDW Name = Source File Name (but with .idw extension when saved)
    With  the IDW=Source File Name, as above, setting the only time that you should be prompted for a file name is if that IDW file already exist that will be the usual windows prompt
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    *Pro
    01-17-2013 06:35 AM in reply to: Rzeszot
    What file name does it suggest?  And what Inventor version are you using?
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Member
    01-17-2013 06:39 AM in reply to: sbixler
    The same as in the left column (see attachment)
    *Pro
    01-17-2013 06:53 AM in reply to: Rzeszot
    In your template, delete the name 'TEST' as shown in your image.  Inventor will then replace it with the name of the template file.  It should now work as you expect.
    When the name of the drawing is edited like that, it forces that name to be used for files created from it.  It might be useful in some situations, but not for you.
    Sam B
    Member
    01-17-2013 07:00 AM in reply to: sbixler
    I've tried to do such thing but I can't delete this.
    *Pro
    01-17-2013 07:12 AM in reply to: Rzeszot
    Can you post the file here?  And please say what version of Inventor you are using.
    Sam B
    *Expert Elite*
    Curtis_Waguespack
    01-17-2013 07:14 AM in reply to: Rzeszot
    HI Rzeszot,
    Try this:
    Open your template file.
    Click once on the file name, and then once again slowly, to select the name, as shown.
    Type a space to replace the name.
    Press the Enter key.
    This should reset the name.
    Then you can save as your template again.
    If that doesn't work please post your file and state the version as sbixler suggests.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    01-17-2013 11:21 PM in reply to: Curtis_Waguespack
    The space button helped in this problem. Thanks for help
    Best regards
