• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Automatic StartMacro error help
    112 Views, 1 Replies
    11-01-2012 12:19 PM
    Hello, I am beginner in autodesk and VBA and got one little problem.
    I already made my model in .ipt and want to change 3 parameters of my model via VBA macro. It works ok but only if I manually start macro in VBA editor/autodesk. But now i need to run this macro on startup when i open my .ipt file (document project).
    I got an init error on my start up macro(cant change parameters(dimensions)of my model)
    This is code in my Form:
    Public Parameter As Inventor.Parameters
    Private Sub UserForm_Initialize()
    On Error GoTo ErrorHandler
    Set Parameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
    TextBox1.Value = 10 * Parameter.Item("dlzkadiery").Value
    TextBox2.Value = 10 * Parameter.Item("diera1").Value
    TextBox3.Value = 10 * Parameter.Item("vysunvystupku1").Value
    Exit Sub
    ErrorHandler:
    MsgBox "Chyba pri inicializácii okna", vbCritical, "Chyba inicializacie"
    End Sub
    Private Sub ButtonUpdate_Click()
    If TextBox1.Value <> "" And TextBox1.Value > 9 And TextBox1.Value < 101 Then
    Parameter.Item("dlzkadiery").Expression = TextBox1.Value
    Else: MsgBox "Dĺžka diery: Zadajte hodnotu v intervale 10-100mm", vbInformation, "Zmena hodnôt"
    End If
    If TextBox2.Value <> "" And TextBox2.Value > 4 And TextBox2.Value < 61 Then
    Parameter.Item("diera1").Expression = TextBox2.Value
    Else: MsgBox "Priemer diery: Zadajte hodnotu v intervale 5-60mm", vbInformation, "Zmena hodnôt"
    End If
    If TextBox3.Value <> "" And TextBox3.Value > 4 And TextBox3.Value < 101 Then
    Parameter.Item("vysunvystupku1").Expression = TextBox3.Value
    Else: MsgBox "Vysunutie vystupku: Zadajte hodnotu v intervale 5-100mm", vbInformation, "Zmena hodnôt"
    End If
    ThisApplication.ActiveDocument.Update
    Exit Sub
    ErrorHandler:
    MsgBox "Chyba pri zmene parametrov", vbCritical, "Chyba parametrov"
    End Sub
    Private Sub ButtonDefault_Click()
    TextBox1.Value = 50
    TextBox2.Value = 50
    TextBox3.Value = 15
    Exit Sub
    ErrorHandler:
    MsgBox "Chyba pri zápise defaultnych hodnôt", vbCritical, "Chyba hodnot"
    End Sub
    Private Sub ButtonExit_Click()
    End
    End Sub
     and this is code in my module
    Public Sub EditParamsAutoOpen()
    UserForm1.Show vbModeless
    End Sub
     Fast help is greatly appreciated
    Please use plain text.
    New Member
    Re: Automatic StartMacro error help
    11-02-2012 03:36 AM in reply to: tomasmik
    bump, still need help, any tips ?
