• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    sato2511
    Autodesk Inventor Optimization
    203 Views, 5 Replies
    07-17-2012 01:58 AM
    Hy!
    I've installed Autodesk Inventor Optimization successfully but when I click on tab Optimization I view the message that I attach. Can anyone help me?
    Thank you very mach!
    sato
    Please use plain text.
    Employee
    xingyuan
    Re: Autodesk Inventor Optimization
    07-17-2012 02:41 AM in reply to: sato2511
    Autodesk Inventor Optimization only available for subscription customer. Please make sure you have log on with an entitled Autodesk ID.
    Sam
    [Sam Yuan]
    [Sr. Software QA Engineer]
    [Alias] Quality Assurance Team
    Autodesk, Inc.
    Valued Contributor
    sato2511
    07-17-2012 02:59 AM in reply to: xingyuan
    Hy,
    when  click on Optimization command Inventor doesn't require ID and PSW, do I have to login with my login name and password
    (Sign IN).
    Thank you.
    sato
    Employee
    xingyuan
    07-17-2012 06:30 AM in reply to: sato2511
    Yes, you do need access. Please refer the link below . http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1892-Collabor1892/1905-Share_d...
    [Sam Yuan]
    Autodesk, Inc.
    Valued Contributor
    sato2511
    07-17-2012 07:56 AM in reply to: xingyuan
    Hy!
    I've log on with an entitled Autodesk ID but I view the same error.
    Thank you!
    sato
    Employee
    xingyuan
    07-17-2012 07:18 PM in reply to: sato2511
    Autodesk ID is not the Subscription Account. You may need pay money for it:smileyhappy:
    Would you mind translate the content of the dialog as English language so that I can see what happen? Is it same with Englishe version below? If yes then you may need check your Subscription Account with your administrator.
    For details of Subscription Account please refer the link below
    http://usa.autodesk.com/adsk/servlet/pc/index?id=17662508&siteID=123112
    Sam
    [Sam Yuan]
    Autodesk, Inc.
