• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    jayxx9
    Accepted Solution
    Autodesk Inventor 2013 compatibility mode.
    828 Views, 3 Replies
    04-30-2012 01:35 AM
    Im trying to do an assignment with Autodesk Inventor. We use Autodesk Inventor pro 2012. For some unknown reason EVERY time i download inventor 2012 pro the installation fails due to a corrupt file. So i thought (In desperation) i would downlaod the 2013 version and see if it would install. Lucky enough it all installed correctly. So i continue with my work on the 2013 edition, and when i go to save it it tells me, that i will not be able to use this file on previous versions. (Which i need to do). Is there by any chance a way to save files, that are compatible with older versins (Like in Word) ?
    Please use plain text.
    *Expert Elite*
    Re: Autodesk Inventor 2013 compatibility mode.
    04-30-2012 03:35 AM in reply to: jayxx9
    Save ipt or iam files as type STEp (*.stp) to open in 2012.
    You are out of luck with idw files (unless you can turn in something like dwf or pdf).
    When you open the *.stp files in 2012 your feature history tree will be gone and your assembly constraints will be gone.
    You might be able to recover the feature tree using the Feature Recognition add in here http://labs.autodesk.com
    Your instructor should have covered all of this (and or help you solve the problem with 2012 in the first place).
    New Member
    01-31-2013 06:56 AM in reply to: JDMather
    does the same concept work with autodesk inventor pro 2013 and 2011?
    *Expert Elite*
    01-31-2013 07:16 AM in reply to: elvishchild
    yes
    STEP *.stp is a neutral format file that can be read by most CAD programs.
