• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Autodesk - FEA Functionality Regression
    655 Views, 9 Replies
    09-03-2010 12:24 PM
    A couple of years ago I would have my student do a weight reduction exercise by creating cuts of various size and shape in a part in the areas that showed low stress/high safety factor.  With the sketches visible and set to Undeformed we could visually see where to change dimensions between analysis.  This visual representation is much more powerful than setting parameter analysis alone (that has it's place too, and we do use that as well).
    But now we cannot see sketches while results are active (must right click and uncheck Active). So we have to toggle between Active/not Active and guess the approximate locations of areas of interest.   I think this behavior regressed in 2010 release.
    There often cases where the human eye and intellegence can reach a solution much faster than the computer tool by itself.
    I hope I have explained this well as I don't have a screen capture of the older behavior.  If not let me know and I will put together some composite images.
    Please use plain text.
    Re: Autodesk - FEA Functionality Regression
    09-03-2010 12:48 PM in reply to: JDMather
    Oh wow, this is truelly maddening.
    By accident I just discovered if I toggle between active part files the dimensions suddenly become visible.
    LOL, whatever workaround works.
    I'll have to experiment on some other machines and see if it is related to my graphics card or something else.
    09-03-2010 12:54 PM in reply to: JDMather
    Well my experiments get even more interesting.
    It is not enough to toggle between open files.
    After running a new analysis toggling to an open file doesn't do the trick.  I have to start a new file and then go back to the analysis part file.
    Employee
    09-03-2010 02:04 PM in reply to: JDMather
    Hi JD,
      You are correct.  We changed the behavior in R2010 such that when results are in view, we turn off the visibility of sketches, workfeatures, etc. automatically so that it won't obscure the view.
      Also note that we cannot access the model browser while in the SA enviornment to turn the visibility back on.
      Would you like me to log a wish list on either of these two items?  Perhaps we can make a setting where you can toggle the visiblilty behavior on or off.
    Thanks and Best regards, -Hugh
    *Please press the 'accept as solution' button if this thread answers your question, so others can quickly benefit*
    Hugh Henderson
    Simulation QA Engineer
    DLS (Simulation and Material Sciences)
    09-03-2010 02:16 PM in reply to: henderh
    Yes, seems to me like it would be an obvious enhancement if you follow the logic of my lab experiment that we do to optimize a part.
    Employee
    09-03-2010 02:22 PM in reply to: JDMather
    Hi JD,
      It is logged in our tracking system as 1343967 "Do not turn off visibility of sketch dimensions with results view".
      Any comment on re-exposing the model browser?
    Hugh Henderson
    09-19-2012 06:54 AM in reply to: henderh
    New semester - my old trick doesn't work in 2013.
    We need to be able to visually see the analysis results and a visible sketch to make intellegent edits.
    Employee
    09-19-2012 09:45 AM in reply to: JDMather
    Hi JD,
      The 2D Sketch Visibility can be toggled on while in results view in R2013 (image attached)
      View tab => Object Visibility pull-down => 2D Sketches checkbox
      I hope this is satisfactory.  Please let us know if you have any additional questions, comments or suggestions.
    Best regards, -Hugh
    Hugh Henderson
    09-19-2012 11:03 AM in reply to: henderh
    I'm surprised that none of my students found that solution this moring - I even offered bonus points if someone could find a solution.
    I guess you get the bonus :smileylol:
    09-19-2012 12:14 PM in reply to: JDMather
    Well in my initial (quick) test that solution doesn't work out well.
    You can change a dimension, but as soon as you except the change you lose the analysis view and have to re-activate it and the sketch visibility.  If you are only making one change at a time and re-running the anlaysis this OK, but if you are making several dimension changes..... ... like x and y position of a hole in addition to diameter....
    We are also using this technique in conjunction with the Parametric Table, but we can visually see areas of easy change when looking at the analysis that as far as I know - Inventor still has no way of recognizing, and even if it did the designer would still have to make the decision based on Design for Manufacturability and other concerns exactly how and what to change.
    We really need to see a persistant sketch and the analysis Shading.
