• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Accepted Solution
    Autodesk 360 file - file locking across multiple locations
    125 Views, 2 Replies
    01-14-2013 12:29 PM
    Does Autodesk 360 cloud storage work in any way shape or form similar to a Vault whereby users can check out, lock, and then check in designs? Can Vault be used in conjunction with Autodesk 360, or does Autodesk 360 eliminate or replace the need for Vault?
    What's the best way for individuals working at multiple sites to work without overwriting each others' data or having save collisions?
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: Autodesk 360 file - file locking across multiple locations
    01-14-2013 12:47 PM in reply to: dick_upton
    Does Autodesk 360 cloud storage work in any way shape or form similar to a Vault whereby users can check out, lock, and then check in designs? no it doesn't work like vault
    this isn't a replacement for vault
    360 is not a file mangement system
    its a file sharing tool its almost  like a ftp site
    01-14-2013 04:14 PM in reply to: dick_upton
    OK thanks.
