Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Authoring iParts
- Highlight
- Email to a Friend
Anyone know if its possible to UN-author an iPart???
Re: Authoring iParts
- Highlight
- Email to a Friend
Just delete the iPart table.
When the table is deleted will convert the intelligent component in a normal part.
That's it?
Application Enginner
Cadtech.Asidek | Autodesk Gold Partner
http://cadtech-asidek.blogspot.com/
www.cadtech.pt | www.cadtech.es | www.asidek.es
Autodesk Inventor Professional 2013
Windows 7 Professional 64-bit
- Highlight
- Email to a Friend
Thanks for your response.
Ideally, I would like to keep the iPart but not have it authored. Being authored as a Tube & Pipe Component I can't place the iPart into an Assembly and change between sizes of the iPart. This feature only works in the Tube & Piping environment.
Miguel.
- Highlight
- Email to a Friend
Hi Miguel,
If you want to remove the T&P authoring from the ipart, please, apply the steps of the solution
http://usa.autodesk.com/getdoc/id=TS13404549
Kind regards,
Alessandro
Alessandro Gasso
Product Support Technical Lead
MFG - Inventor
Autodesk, Inc.
- Highlight
- Email to a Friend
Thanks Alessandro. You just saved me days of work. Much appreciated.
- Highlight
- Email to a Friend
You seem very knowledgable...i have another weird question for you? Is there a way to remove solid bodies from a part file. For example...i have created a part file that has around 30 features and counting. Towards the end i accidently clicked on create new solid button and now have a new solid...but i didn't realise that i did this. I then continued creating further features and now find limitations in what i am doing. Can i reverse the Solid body so that its just a regular feature????
- Highlight
- Email to a Friend
Hi Miguel,
Please, try the following.
- Drag the End of Part below the feature you has created as solid.
- Edit the feature and change it to a normal one.
- Then, drag the EoP under the feature below, possibly one by one.
Hopefully, the majority of the feature will recalculate correctly while few others need to be redefined as you can see in the video attached.
I hope it helps.
Kind regards,
Alessandro
Alessandro Gasso
MFG - Inventor
Autodesk, Inc.
- Highlight
- Email to a Friend
Thanks Alessandro. I shall give it a try later on today.
Miguel.
