Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Associatin g Two Sketches In A Frame Generator Assembly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have sketches that are used in framed shower door assemblies and I am trying to use the main sketch as the outside perimeter w/ associated parts while the door is separate so it can pivot independently from the rest of the assembly. My question is: How do I associate the door sketch to change size when the door opening changes size in the main sketch?
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Re: Associatin g Two Sketches In A Frame Generator Assembly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Steve,
For now, Inventor doesn't have such functionality to associate geometries between two sketches. We've already taken this into consideration and try to make this in the future. Thank you very much for pointing out your questions.
Best Regards,
Debbie
Debbie Lou
SQA Engineer
Inventor Quality Assurance Team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Debbie. What about using a dummy parameter file to drive the sizes?
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attached is a quick example of what I understand you are asking for
May well be wrong in my understanding, though
Adjusting either of the two parameters in the FrameSketch will propagate to the door part
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Looks like you understand what I'm trying to do. So from what you created I would open the Door&FrameTemp.iam and control it from the FrameSketch.ipt. Now I just need to understand how you linked the two successfully. It's been a while since I tried it. I'll give it a try and let you know how I make out. Thanks!
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay, now that I'm thinking about this the model you sent to me is simple enough to do without associating the frames. Where it starts to be more complicated is when there's a door with at least one fixed panel like in the attached image. Now the door size (26") will drive the panel size (11.027") or if I change the overall width (40") the door stays the same but the fixed panel changes accordingly. I've done this in the SK (attached) but like I said I need the door to swing open in the assembly as a representation.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure I understand the problem here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That looks like it works. I guess I'm not understanding how to link the two frames together.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried to do this many times but I'm not able to link the parameters. Can you give me any pointers? Thanks.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
