• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    Assembly trim
    174 Views, 3 Replies
    11-29-2012 07:58 AM
    Hello
    I'm coming from NX(Siemens) and I'm learning now to work with Inventor.
    I've an assembly as you see it in the picture below. In this assembly i need to trim the green tube, in NX I would need to use 2-3 features. What is the best way to handle this problem with an associative way?
    As I've seen derive isn't working, because it causes a cyclic dependency.
    Is there a way to link the green part into the sheet metal part at the same position as it is in the assembly?
    Kind regards,
    GUtz_CH
    Please use plain text.
    Distinguished Mentor
    Re: Assembly trim
    11-29-2012 09:17 AM in reply to: GUtz_CH
    I'm assuming you want to trim the green part to look like the cylinderical grey part at the bottom of the sheet metal part.
    One way:
    In the assembly, edit the green part. If one's not available in the green part, create a plane parrallel to the edge of the sheet metal part. Start a sketch on that plane. Project geometry the edge of the sheet metal part that will trim the green part. Hit E to extrude. Pick the appropriate side of the open profile, change to cut and adjust termination type or distanc as necessary,
    Re: Assembly trim
    11-29-2012 09:25 AM in reply to: GUtz_CH
    You can also
    edit the part in context of assembly
    Copy Object surface from part to use for trimming
    Split or Sculpt to trim the part.
    The result is associative.
    Derived Components will also work if done correctly,
    and multi-body solids is another option.
    Inventor Professional 2014 Edu 64-bit
    New Member
    Re: Assembly trim
    11-29-2012 10:50 PM in reply to: JDMather
    Thank you a lot, both solution are very helpful!
