Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Assembly to part file linked parameters .
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My goal is to open have people go into a central assembly file, type in their specific parameters and the various part files update within the assembly. I wish to do this without the need for an excel sheet, but when I try to link the parameters from the assembly file to the part files, it will not allow me to insert these parts. I get an error about an "assembly can not be placed into itself."
Iparts will not work as this has an infinite amount of sizes.
Thanks in advance.
Re: Assembly to part file linked parameters .
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
create a dummy part with parameters, insert into your assembly, when you start a new part derive this dummy part into it and take the parameters you need, when you update the dummy part all the other parts will update...
do a search here for skeletal or master sketch modelling
Autodesk Product Design Suit 2012
Win 7 Enterprise 64bit
Intel core i7 2600K Clocked @ 4.7GHz
16Gb Ram
Nvidia GTX 580
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It is also possible to have the parameters in your assembly and then use an iLogic rule to push their values out to the part files.
Inventor 2013
Windows 7 64 Bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think I was accomplished what you are trying to do. Not 100% sure,
I wanted to have a finished assembly file, that could altered by changing specifc parameters.
in my case, the 'skeleton' file dives the frame size. the sheet metal panels are a linked to the frame size, so if the frame size changes then the panels change accordingly.
See this link:
I solved my own question, in the last post there is a link to a set of short videos, these were VERY helpful...
Let me know if it is what you were looking for.
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 314.22
