Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Assembly Template Bill of Materials Item Numbering
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not a deal breaker but very annoying -
Since moving to 2010 and making a change to the assembly template the item numbers under the BOM structure have started with 8 rather than one. It seems that no matter what I do there is no way to revert it to 1 meaning that every one of my users assemblies must be renumbered. What's worse is that every attempt to correct the issue ends up driving the number up one (at 16 now).
Is there a way to reset the item number to start at one in a template?
Eric
Inventor 2010 Pro 64bit - SP3
Vault Manufacturing 2010 Admin
Windows 7 Pro 64bit
Quad Core processor 2.26 Ghz
16 GB DDR3 RAM
1.5 GB Nvidia Quadro FX 4800
2 – 320 GB SATA drives
Re: Assembly Template Bill of Materials Item Numbering
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you open a new drawing file with your template - then save it as a new template file, it will reset the view label numbers and letters etc,
So im guessing if you open a new assembly file and save as a new .iam template, it should reset the BOM numbering?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That didn't work but I was very hopeful for a moment, until I realized I hadn't switched over to structured. Thanks for the attempt.
Eric
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I see that you have the same promblem as me and I was wondering if you found a solution for it yet?
Malin
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually yes, one of our users figured it out a few weeks back.
RMB the structured tab, select disable BOM view, accept the warning then re-enable structured BOM view. This did the trick.
Eric
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you so much!
I've been working with this for three days and not being able to fix it.
Malin
