• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Assembly Constraints Snowballing Errors
    180 Views, 2 Replies
    11-16-2011 01:48 PM
    I have a bunch of assemblies that are acting this way and I am not sure why.
    I ahve built the parts and built the sub-assemblies with-out errors, once everything looks good I place the subassemblies into my top level assembly.
    Everything still looks good with no errors.
    I do a rebuild of the top level assembly and find 20 or so errors.
    Most of the errors are bogus and editing the constraint with-out changing anything removes the errors, typicaly.
    On a bunch of the sub-assemblies the error showed up in the top level assembly, so I edit the part only to find the constraint is relevant but with errors so I suppress it to remove the error. Save and go back to the top level assembly only to find there is another constraint error in the same assembly that I suppresed the constraint to remove the error. This goes back and forth between top level and sub-assembly till all constraints are suppresed or deleted for the sub-assembly. Then the same thing happens to another sub-assembly.
    This is driving me crazy, the only solution that I have found is to delete all constraints and rebuild each sub-assembly with the same constraints that were initialy used.
    How do I stop this snowball effect???????????????????
    Please use plain text.
    Employee
    Re: Assembly Constraints Snowballing Errors
    11-16-2011 03:03 PM in reply to: DSNR
    Hi! Could you send me the files so I can take a look?
    Thanks!
    Principal SQA Engineer, Inventor
    Manufacturing Group
    11-17-2011 06:07 AM in reply to: johnsonshiue
    I think I have it figured out...
    For some reason I deleted a assembly constraint, re-constrained it in the exact same way and all the other constraint errors disappeared. Not sure why or how but it worked.
    Thanks anyway, much appriciated!!!
