• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Assemble Multiple leds on matrix
    111 Views, 4 Replies
    09-26-2012 06:02 AM
    Guys,
    I am assembling multiples leds on a matrix that I made.
    Is there any way to make the assembly using constrains to place the ipt LED design on the matrix without placing one by one?
    The constrain I am using for each led is Insert.
    There got to be a way to insert the leds directly, like when you are placing screws and it detects all holes and places the necessary number os screws on the existing holes.
    Any Idea will be aprecciated.
    Fefas
    Please use plain text.
    Cadmanto
    Re: Assemble Multiple leds on matrix
    09-26-2012 06:13 AM in reply to: Fefas
    Fefas,
    Have you looked into patterning?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    09-26-2012 07:32 AM in reply to: Fefas
    If you created the holes in the original part with a Feature Pattern you can use that same part Feature Pattern to place the LEDs in the assembly.
    Member
    09-26-2012 08:08 AM in reply to: Cadmanto
    Thanks Scott,
    It worked. I don't know how I haven't noticed that on the assembly I could use the patter tool.
    Cadmanto
    09-26-2012 08:12 AM in reply to: Fefas
    We all over look things at time.  Glad it was that easy.
    Best Regards,
    Scott McFadden
