• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Annotate problem: leader with text
    128 Views, 3 Replies
    10-03-2012 04:48 AM
    Is it possbile to spread text gathered from the part description on 2 lines? cause on 1 line is in this case to long.
    Inventor 2012
    Please use plain text.
    *Pro
    jletcher
    Re: Annotate problem: leader with text
    10-03-2012 05:04 AM in reply to: Jefkee
    Yes but you have to make it a symbol and use text box put a dimension on the text box to control the text wrap.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    *Pro
    jletcher
    10-03-2012 05:24 AM in reply to: Jefkee
    There is another way but I can't find my cheat sheet that tells me how. There is a character you can place in the description and then you don't need to make a symbol but I can't remember.. If I find it I'll post..
    James Letcher
    Valued Mentor
    mpatchus
    10-03-2012 05:30 AM in reply to: Jefkee
    Another option is to make use of the part's COMMENTS iproperty.
    In the past, I have utilized this iproperty for part descriptions so I could "break up" a long single line of text.
    Simply use the ENTER key to break the text up as desired.
    It's a workaround, but it does the trick for those clients of mine with long-winded part descriptions.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
