• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    andrewwhiteinc
    Accepted Solution
    Animation Fade Rates for Parts when Fading In Assy NOT UNIFORM
    183 Views, 6 Replies
    11-06-2012 11:43 AM
    Hey Guys, I'm having a world of problem with something so simple.
    I have an assembly that I want to fade in from 0 to 100. In the animation, I set the assembly to fade to 0 instantly. I then add a fade from 0 to 100% starting at 0 ending at 5 and several parts are starting to fade in then fading back out until the very end they all suddenly appear.
    I've done everything I can think of with this assembly from clearing all animations out to completely rebuilding this assembly.
    Does this really have to be so hard?!?!?!?
    P. Andrew White,EIT
    Engineer-in-Training, Industrial Automation
    Please use plain text.
    Valued Mentor
    Re: Animation Fade Rates for Parts when Fading In Assy NOT UNIFORM
    11-06-2012 11:46 PM in reply to: andrewwhiteinc
    hi,
    to better understand your situation, can you post up a picture of the animation timeline for this.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    Active Contributor
    andrewwhiteinc
    11-07-2012 10:40 AM in reply to: Mark_Wigan
    Problem solved, had to roll back my video card driver and it works now.
    P. Andrew White,EIT
    Active Member
    01-07-2013 05:51 AM in reply to: andrewwhiteinc
    i'm having the same problem. can you explain what you mean by "roll back my video card driver"?
    Active Contributor
    andrewwhiteinc
    01-09-2013 08:38 AM in reply to: jared
    Hey, I uninstalled the current driver and reinstalled an old version of the Nvidia driver, can't remember where I found it but I realized after this post that the problem reappeared.
    Turns out that it is only a problem when you are previewing the animation or processing the video without rendering. Seems to (but not confirmed to) be an issue with Inventor itself. If you render the animation it should appear correctly.
    P. Andrew White,EIT
    Active Member
    01-09-2013 08:53 AM in reply to: andrewwhiteinc
    i did notice that it works better if rendered, but my assemblies are very large and i don't really need them rendered (they look fine without shadows and reflections). besides it literally takes about 4 days to render my 3 min. animation (as opposed to only about 3hrs unrendered). thanks for the update! i guess i'll just have to deal or open up my schedule...lol.
    Active Contributor
    andrewwhiteinc
    01-09-2013 09:58 AM in reply to: jared
    yea mine was the same, 2 minute video ran from friday @4 until monday at lunch lol
    P. Andrew White,EIT
