• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Re: Animating Positional representations in Studio
    09-24-2010 09:41 AM in reply to: nrg_drink
    I can't speak for the user who started this thread but in my case, I don't have to do nothing in the "Studio" environnement to get the error. It pops up when I switch from the "Assembly" environnement to the "Inventor Studio" environnement. I'm not using Excel in any way in this model and I get the error. I'm not using Positionnal Reps either in my animation. I'm using positionnal reps in my assembly but not in the animation. In assembly mode, the positionnal reps work fine.
    When I switch to "Studio" environnement, I get the error. Then, Inventor returns to the "Assembly" environnement. I click again to go to the "Studio" environnement and this time, no error message and I'm able to render and animate. But, again, I'm not using positionnal reps. Maybe if I did, I would get another error message.
    Specs:
    Inventor 2010 Pro SP2 (I removed SP3 because with this SP applied, the rendering crashes all the time)
    Windows 7 - 64 bit
    Nvidia Quadro FX 3700 with lattest driver approved by Autodesk for Inventor 2011.
    If you need more info, please ask!
    Thanks.
    Please use plain text.
    Employee
    09-24-2010 11:18 AM in reply to: pdauphin
    So, the initiator of the discussion has this setup...
    Inventor Pro 2011 (64 bit)
    Windows 7
    Excel 2007
    You have...
    Windows 7 - 64 bit
    What version of Excel do you have on your machine?
    Bill Bogan
    Principal Content Developer
    Design, Lifecycle, and Simulation
    Autodesk, Inc.
    Valued Contributor
    09-24-2010 11:29 AM in reply to: pdauphin
    Excel 2007.
    Employee
    09-24-2010 11:37 AM in reply to: pdauphin
    So, the common threads are:
    Windows 7
    Excel 2007
    And, how Inventor 2010/2011 reacts to these. I'll log this as an issue and see what can be determined.
    Bill Bogan
    Autodesk, Inc.
    New Member
    KoosKrugel
    11-29-2010 05:08 AM in reply to: bill.bogan
    Hi
    I have the same problem as pdauphin.
    System also pretty much the same.
    I want to animate positional representations.
    Also, when I want to open the excel sheet containing the PosReps, it gives the same problem.
    Is there any solution yet?
    Employee
    11-29-2010 08:24 AM in reply to: KoosKrugel
    The issue has been reported. When I get word back on it, I will update the response here.
    Bill Bogan
    Autodesk, Inc.
    Member
    juan.j.alfonzo
    11-03-2011 03:50 PM in reply to: pdauphin
    Has this problem been resolved? I have exactly the same problem with inventor 2010, I am trying to animate an  assembly including positional representations and it keeps saying that Excel is required to animate pos. rep., it crashed 3 times already, so I closed Inventor opened it again a nothing, keeps doing the same thing, the 4th time I tried it sent another message:
    -Could not insert object
    -Failed to launch excel
    and then... it crashed...
    Excel 2010
    AI 2010
    Intel Core i7 2600 cpu
    16 gb ram
    64 os
    Employee
    11-07-2011 08:00 AM in reply to: juan.j.alfonzo
    I am told this defect was fixed with Inventor 2011 SP2. If you are on 2011, be sure to apply SP2.
    If you are using something newer, let us know as it would mean a regression has taken place.
    Bill Bogan
    MFG Learning Experience Team
    Bill Bogan
    Autodesk, Inc.
    New Member
    04-28-2012 09:08 PM in reply to: pdauphin
    It appears I am having similar issues.  I tried animating with PR's, but as I couldn't get it to work, I went back, and deleted the PR's, and tried the animation with component animations.  Now, every time I enter the Studio, I get the error message about not having Excel installed, and Inventor crashes just at the completion of rendering my animation.
    My setup:
    Windows 7 Pro 64bit
    Excel 2010
    Inventor 2012
    Quad core 2.83GHz
    8gb Ram
    gtx 580
