• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Animating Positional representations in Studio
    911 Views, 18 Replies
    08-03-2010 02:15 AM
    I'm using 2011 pro.  When I try to animate a positional rep in inventor studio, it complains that I don't have excel installed. (see attached image) although I do have it installed.  I've put the hotfix on for excel, with no effect.  I've repaired inventor and repaired excel no fix though.
    Does anyone have any ideas ?
    Please use plain text.
    Re: Animating Positional representations in Studio
    08-09-2010 03:39 AM in reply to: nrg_drink
    I thought I would try and bump this up, I really need an answer, I hope someone can help
    Employee
    08-09-2010 07:39 AM in reply to: nrg_drink
    We should probably start with basic information.
    Inventor version? Default install path or other?
    Excel version?
    Machine info?
    Bill
    Bill Bogan
    Principal Content Developer
    Design, Lifecycle, and Simulation
    Autodesk, Inc.
    08-10-2010 01:56 AM in reply to: nrg_drink
    Sorry,
    I'm using Inventor Pro 2011 (64 bit)
    Windows 7
    Excel 2007
    Dell M6500 12gb Ram
    There are other people in the office using exactly the same spec, and they have the same problems
    08-10-2010 01:57 AM in reply to: nrg_drink
    and everything is installed to the default paths, both excel and inventor
    Employee
    08-10-2010 08:28 AM in reply to: nrg_drink
    Great. thanks! We'll see what we can discern at this point. I or another person will be back with more information as soon as I/we have it.
    Bill Bogan
    Autodesk, Inc.
    Employee
    08-11-2010 10:29 AM in reply to: bill.bogan
    Try this post: http://forums.autodesk.com/t5/Autodesk-Inventor/linking-an-excel-file-using-inventor-2010-and-window...
    Saving you time...
    Re: linking an excel file using inventor 2010 and windows 7
    05-06-2010 12:40 PM in reply to: pmoske
    Is this a 64-bit system? These solutions are only for 64-bit Windows 7.
    Did you try running the script again to remove the entries, then again
    to add them? (Soren Skjoldborg tried that back in November and it helped.)
    Microsoft acknowledged the problem is with the interaction between
    Windows 7, its default entries for things like searching, and Office.
    You can see that even things like WordPad exhibit the same bad behavior
    by trying to link a spreadsheet to a document in WordPad (it embeds it
    instead of linking to it). I don't know what the status is for a fix
    from them.
    One other approach you might want to try is to rename the key yourself
    (I recommend renaming so you can restore it if things don't work). Use
    Registry Editor and find
    HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{00020820-0000-0000-C000-000000000046}.
    Rename that key to something else, perhaps by prepending "zzz"
    ("zzz{00020820-..."). By doing that, it forces Windows to use the 32-bit
    entries, and that should work.
    You can confirm this by trying to link a spreadsheet into a WordPad
    document---when things are broken, it will only embed (you'll see a
    spreadsheet icon), but when things are working, it will be linked
    (you'll see the spreadsheet entries).
    Bill Bogan
    Autodesk, Inc.
    08-16-2010 03:11 AM in reply to: bill.bogan
    It's not that, I can quite happily link excel tables into IParts etc (although the hotfix was required) It's just animating the postional representations that cause a problem
    Valued Contributor
    09-24-2010 05:52 AM in reply to: nrg_drink
    Any solution came up for this problem? I have the same problem here...
    Thanks.
    Employee
    09-24-2010 08:50 AM in reply to: nrg_drink
    Let me see if I understand this correctly...
    1. You bring values from excel into Inventor. Do you assign them to/as parameters?
    2. You then use the parameters/values to modify PRs. The PRs work in the assembly environment - no problem?
    3. In Inventor Studio, you use the Animate Positional Representations (PR) command to animate between specfied PRs
    Does that accurately describe the process - albeit more steps may actually be required?
    And, if that is the process, are you having problems with phase 3?
    Bill Bogan
    Autodesk, Inc.
