Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Angled dimention
- Highlight
- Email to a Friend
Hello
I am working with a IDW and i can not get the angled dimensios to line up with the object that is a cross beam with angled ends. I trying to put in the length of each beams. Workt in Autocad mechanical.
Patrik
Design suite premium 2014
Clevo p370em CPU-I7-3840QM single-680m 32ram
MSI Bigbang 2 CPU-3960x MSI-7970 X-fire 32ram
Re: Angled dimention
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Hi
Thanks..Ok i will try i have JPE
I did try in Inventor std 2013
First try..
Patrik
- Highlight
- Email to a Friend
Ok here it.s done with Autocad and it works good.
Patrik
- Highlight
- Email to a Friend
You will have to add a sketch construction line within the view.
Inventor Professional 2014 Edu 64-bit
- Highlight
- Email to a Friend
Hi..
Thanks ok i did try that and i am now in a 1:10 scale so i got one 10 of my dimention and then i have to over ride. If i now did it all in the right order?
Anyway i under stand this right there is a differens in Inventor and autocad. So i have to work around that.
Patrik
- Highlight
- Email to a Friend
There is nothing to override.
Create the sketch.
Exit the sketch.
Add the dimension.
Attach all of youf files here.
In AutoCAD you are creating all of your documentation (2D) geometry.
In Inventor you are creating just some of it while the overwhelming majority is generated from the 3D model.
- Highlight
- Email to a Friend
Thanks for your time...
Ok i just can not find the construction command when i am in the idw sketch. I can find construction command in the part sketch.
I use the std 2013 inventor have i perhaps missed something? i made a mistake of using the centerline first.
Patrik.
- Highlight
- Email to a Friend
As JD has mentioned, you have to create a simple construction line. I do support your question and you do actually raise an excellent point. I too have drawings like the one you have shown and it would be great if Inventor caught up to Autocad in this regard. Why should we have to create a construction line when there should be a way to simply align the dimension to the object and pick two points like you show.
I think it would be great for Inventor to add this feature!
Rob
- Highlight
- Email to a Friend
I knew I had seen something similar a while back.
Bit of a search and found it.
Have a look here for julesgf solution
