• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Active Member
    Angle entry for contour flange command?
    51 Views, 6 Replies
    11-13-2002 03:29 AM
    While designing a sheet metal part, I needed to make a contour flange. However, that command was useless to me, because it doesn't seem to have an option for user input angles. It works great for pieces with a 90 deg angle, but not anything more or less than that. Can anyone help me with this?
    Please use plain text.
    *Keller, Kent
    Re: Angle entry for contour flange command?
    11-13-2002 03:50 AM in reply to: dmeadows
    I am probably missing it but can't you just draw what ever angle you want?
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "dmeadows" wrote in message news:f122fcf.-1@WebX.maYIadrTaRb...
    Active Member
    Re:
    11-13-2002 04:10 AM in reply to: dmeadows
    Well, I failed to mention it, but it has a joggle in it.
    Active Member
    Re:
    11-13-2002 04:26 AM in reply to: dmeadows
    The joggle is on the edge of the bend.
    *Keller, Kent
    Re:
    11-13-2002 04:44 AM in reply to: dmeadows
    Can you post something to customer files. It always helps to be looking at the same
    thing. 8^)
    Kent
    "dmeadows" wrote in message news:f122fcf.2@WebX.maYIadrTaRb...
    Active Member
    Re:
    11-13-2002 08:04 PM in reply to: dmeadows
    How do I post it?
    *Brown, Anne
    Re:
    11-13-2002 10:46 PM in reply to: dmeadows
    dmeadows -
    Customer Files (CF) is an area for upload of problem files for
    review or sharing. Users are asked to zip any files prior to
    uploading to conserve download time and server space. Post as an
    attachment to your message in CF.
    For NNTP newsgroup readers the Customer-files newsgroup can be
    found at
    news://discussion.autodesk.com/autodesk.autocad.customer-files.
    You may also access the customer-files group via the HTTP
    web-based forums at
    http://discussion.autodesk.com/WebX?14@@.ee940b5.
    Anne Brown
    Manager, Moderator
    Autodesk Product Support Discussion Groups
    Discussion Q&A: http://www.autodesk.com/discussion
    dmeadows wrote:
    > How do I post it?
