• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Alternative Packages not recognising Spline
    121 Views, 3 Replies
    01-23-2013 06:01 AM
    I am drawing an airfoil profile in Inventor for use in a CFD package. I have a system of points which I am plotting and connecting via the spline function and extruding them to form my blade profile. However, when I open the drawing in the CFD programme, it is recognising the spline as a series of straight lines instead of one continuous enclosed shape. The CFD programme I am using require a negative (i.e a solid drawing of where fluid is flowing). I have attached the inventor file I have created. I have a feeling there is probably a very easy fix to this problem. Any help would be greatly appreciated.
    Sean
    Please use plain text.
    Employee
    Re: Alternative Packages not recognising Spline
    01-24-2013 09:46 AM in reply to: Sean.cooke
    Hi Sean,
    Welcome to the forum!
    I'm sorry to hear that you're having trouble. If you zoom in on Sketch1 you will see that you are in fact creating a series of straight lines from the beginning (see screen capture below).
    I also noticed that your sketches are unconstrained; are you new to Inventor? If so, you may find JD Mather's SkillsUSA document of use:
    http://home.pct.edu/~jmather/skillsusa%20university.pdf
    Please feel free to follow up with anything else - hope this helps.
    Indy
    Inderjeet Wilkhu
    SQA Engineer
    Autodesk ShapeManager
    Design, Lifecycle and Simulation
    New Member
    01-24-2013 10:59 AM in reply to: wilkhui
    Thank you Wilkhui,
    I managed to fix the problem this afternoon. I redrew my airfoil blade in inventor and there was no problem with my CFD package recognising it correctly. Im not new to inventor but I am quite rusty, it has been about 3 years since I have used it last.
    Thanks again for taking the time to look at my problem,
    Best Regards,
    Sean
    Employee
    01-24-2013 11:14 AM in reply to: Sean.cooke
    Hi Sean,
    No problem at all - glad to hear that you've got it to work for you :smileyhappy:
    Please don't hesitate to get in touch should there be anything in future and happy CFD'ing!
    Best wishes,
    Indy
    Inderjeet Wilkhu
    SQA Engineer
