Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Alternativ e Packages not recognisin g Spline
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am drawing an airfoil profile in Inventor for use in a CFD package. I have a system of points which I am plotting and connecting via the spline function and extruding them to form my blade profile. However, when I open the drawing in the CFD programme, it is recognising the spline as a series of straight lines instead of one continuous enclosed shape. The CFD programme I am using require a negative (i.e a solid drawing of where fluid is flowing). I have attached the inventor file I have created. I have a feeling there is probably a very easy fix to this problem. Any help would be greatly appreciated.
Sean
Re: Alternativ e Packages not recognisin g Spline
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Sean,
Welcome to the forum!
I'm sorry to hear that you're having trouble. If you zoom in on Sketch1 you will see that you are in fact creating a series of straight lines from the beginning (see screen capture below).
I also noticed that your sketches are unconstrained; are you new to Inventor? If so, you may find JD Mather's SkillsUSA document of use:
http://home.pct.edu/~jmather/skillsusa%20universit
Please feel free to follow up with anything else - hope this helps.
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk ShapeManager
Design, Lifecycle and Simulation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you Wilkhui,
I managed to fix the problem this afternoon. I redrew my airfoil blade in inventor and there was no problem with my CFD package recognising it correctly. Im not new to inventor but I am quite rusty, it has been about 3 years since I have used it last.
Thanks again for taking the time to look at my problem,
Best Regards,
Sean
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Sean,
No problem at all - glad to hear that you've got it to work for you ![]()
Please don't hesitate to get in touch should there be anything in future and happy CFD'ing!
Best wishes,
Indy
Inderjeet Wilkhu
SQA Engineer
