• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    eveylynne
    All around symbol
    344 Views, 8 Replies
    02-03-2012 01:21 PM
    Is there a way to add the all around symbol to a note or dimension?  I see how to add it to a weld symbol and a feature control frame, but that doesn't help me too much just yet...
    Distinguished Mentor
    Re: All around symbol
    02-03-2012 01:32 PM in reply to: eveylynne
    would the "Circularity" symbol work?
    Ref attached.
    Active Contributor
    eveylynne
    02-06-2012 05:05 AM in reply to: ampster
    Alas, it would not.  I need the symbol on the leader for all around profile.
    02-06-2012 03:17 PM in reply to: eveylynne
    Do you mean something like in the attached? If so - it all controlled by Surface Texture DB.
    Best Regards,
    Igor.
    Web: www.meqc.com.au
    Active Contributor
    eveylynne
    02-07-2012 12:04 PM in reply to: IgorMir
    Yessin.
    It needs to be on the first jog of the leader, closest to the arrow head.
    02-07-2012 03:28 PM in reply to: eveylynne
    Well, I am out of suggestions. What you are asking for is certainly not in the Australian standard AS 1100.
    Which standard do you reefer to?
    Igor.
    Active Contributor
    eveylynne
    02-08-2012 05:09 AM in reply to: IgorMir
    Alas, I am not referring to any standard.  The print I am wanting this note for would stay on house, so I am trying to simplify the language.  It would be in reference to a radius around a complicated profile.  I'm simply going to add "ALL AROUND" to my dimension and leave it at that.
    Thank you for all the suggestions!
    -Evelyn
    02-08-2012 03:55 PM in reply to: eveylynne
    Hi Evelin,
    While technically you can create a symbol you are after using Sketch symbols tool (see the attached) I still would be very shy to deviate from the National Standard.
    Igor.
    Active Contributor
    eveylynne
    02-09-2012 08:10 AM in reply to: IgorMir
    Thank you.  I'm just adding "ALL AROUND PROFILE" and leaving it at that.
