• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    lemaycj
    Aligning parts
    157 Views, 4 Replies
    04-19-2012 04:01 PM
    Here's another one which I am sure is an easy task for most but has me frustrated....
    I have added 4 gussets to my assembly of two parts.  All I am trying to do is to align the gussets 90 degrees apart from each other and starting at 45 degrees on each side of the tapped hole.  I have one almost positioned except it can still move along the surface.  How should I tackle this?
    Please use plain text.
    Valued Contributor
    cean_au
    Re: Aligning parts
    04-19-2012 04:56 PM in reply to: lemaycj
    when u finish the first, array out the rest.
    and if you creat one part insetad of an assembly, the gusset can be rib feature, much eash to creat.
    Active Contributor
    lemaycj
    Re: Aligning parts
    04-24-2012 08:41 AM in reply to: cean_au
    The problem with this issue is not how to do the next 3 but how to secure the one where it needs to go and/or is there a better way than the way I was placing that gusset to be more efficient at it.
    Jonka45
    Re: Aligning parts
    04-24-2012 09:05 AM in reply to: lemaycj
    You are virtually there, Use a mate constraint from the plane you created to the plane through the center of the gusset then pattern the gusset to get 4 instances at 90 degrees.
    Inventor 2013
    Dell Precision T3500 Intel Xeon
    Windows 7
    Quadro 4000
    Inside Leg 35 inch
    Re: Aligning parts
    04-24-2012 09:10 AM in reply to: lemaycj
    Mate the workplane to the central axis.
    Inventor Professional 2014 Edu 64-bit
