• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Air Trap Analysis 2012
    192 Views, 4 Replies
    10-16-2012 11:35 PM
    Somebody help me.
    I can't find the air trap analysis for 2012. it says it does not run such analysis in 3D. For some parts however, it did run. Is there any way to solve this problem???
    Please use plain text.
    Valued Contributor
    Re: Air Trap Analysis 2012
    10-17-2012 12:28 AM in reply to: ericjed13
    Well, run the 2.5D flow analysis on the surface mesh defined by the 3D mesh. It should show the airtraps.
    10-17-2012 01:06 AM in reply to: abakharev
    Okay, and how do i do that exactly? :smileyfrustrated:
    Valued Contributor
    10-17-2012 09:40 PM in reply to: ericjed13
    Select your study.
    Right click on the 3 D Mesh label:
    In the Pull-down menu select Set Mesh Type.
    Choose Dual Domain.
    The label now is is Dual Domain Mesh. If the surface mesh were present, you would see some some none zero number of elements. If the surface mesh was not stored in the study you would see 0 elements:
    Right click on it once more and select "Generate mesh".
    After meshing is finished start the analusis and enjoy the Air Trap plot.
    10-17-2012 10:26 PM in reply to: abakharev
    Wow! Thanks for that!
