• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Mason-Paul
    Re: IRe: Add-in Thread Modeler Issues
    01-23-2013 10:02 AM in reply to: Rfechner
    Add-in sure is wrong 55 deg is BS Whitworth angle of thread where as Metric is 60 deg.
    DID you look at the OTHER attachments the square cut thread example??
    Here is the part that thread on that spindle mates with, it'll give you an idear of how to cut/form internal threads, then add a not on your drawings.
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    Please use plain text.
    Active Member
    01-23-2013 10:12 AM in reply to: Mason-Paul
    Hi Mason-Paul,
    I did look at your examples, thank you for providing those. I now understand I should stay away from the add-in. I hope people are not blindly using it expecting the threads to turn out correct. It got me in a little hot water here at work!
    Ryan
    01-23-2013 10:28 AM in reply to: Rfechner
    From the Quick Start.doc
    British Standard Whitworth
    Active Member
    01-23-2013 10:32 AM in reply to: JDMather
    This certainly explains things, I feel rather silly now. If only I would have taken the time to read.
