• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    luiww
    Access denied
    118 Views, 1 Replies
    11-16-2012 08:25 PM
    I have the problem with a message, access denied.  Attached is the screen shot of the message as well as the ipt file.  The part file is also created by me then but not able to amend it now.
    Please use plain text.
    blair
    Re: Access denied
    11-17-2012 02:02 PM in reply to: luiww
    Possibly you are trying to do a "Save-As" while the part is still being accessed by the Assembly file IAM. You would need to close the assembly to do a "Save-As".
    Looks like you opened the assembly, selected one of the parts within the assembly to edit and are trying to change the name of the part with the Save-As command. You should be using the "Save Copy As" command for this work method.
    If you closed all the files and just opened this single IPT file then your method of the "Save-As" would work.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
