• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    About part list
    132 Views, 4 Replies
    06-20-2006 02:33 AM
    Hi
    Does somebody know why cells appear in yellow in my part list ? (see attach file)
    Please use plain text.
    Distinguished Contributor
    Re: About part list
    06-20-2006 02:43 AM in reply to: eliyae
    if you renumber the items manually and duplicate a number it goes yellow, not sure why yours are
    *Dan Szymanski \(Autodesk\)
    Re: About part list
    06-27-2006 11:46 AM in reply to: eliyae
    Stee is correct.
    ITEM cells, within the ITEM column of a parts list, turn yellow anytime a
    value is duplicated. It is a visual warning that two instances of the same
    ITEM # exist within your parts list. This rule applies to numbers, letters,
    symbols and even empty cells. The attached image submitted by Elie displays
    six duplicate cells that contain no value at all and duplicate values of
    ITEM # 32 & 33.
    Dan Szymanski
    Inventor QA
    Autodesk, Inc.
    wrote in message news:5211759@discussion.autodesk.com...
    Re: About part list
    11-19-2012 02:57 AM in reply to: eliyae
    I've recently come across the same issue on my home machine.
    My question is if I place two or three parts into an assembly how can they have the same item number? Would not the first part go in as item one and so on?
    Regards.
    Inventor Professional 2014.
    Windows 7 64 bit.
    *Expert Elite*
    cbenner
    Re: About part list
    11-19-2012 08:52 AM in reply to: PaulB108
    Are the items all the same part number? And are they merged by part number as below?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
