Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
3d lines in inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just switched from Inventor 2011 to 2013 and find the procedure to make 3d hose and tubes has changed a lot. Where can I find a tutorial or video that explains the procedure. I have looked at the tutorial work features video and the various help sections, but still do not understand the process. Thank you. Phil
Re: 3d lines in inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is this what you are looking for?
http://wikihelp.autodesk.com/Inventor/enu/2013/Hel
or is that what you have already looked through?
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It got me started. I am trying to make hoses between hose ends I have in my library (using hydraulic hose-no fittings style), not ones from the content center (I don’t seem to have those anyhow). I can construct the route between the two hose ends (after a fashion), but do not know how to get the hose on the route. In 2011 I’d simply sweep a 2d sketch along the 3d line. Can you give me some tips on how to do this. The tutorial does not seem to cover this scenario. Also, is it possible to use the same method I used in 2011. I’ve made hundreds of hoses with that method and it worked very well. Thank you. Phil
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have one more question on 3d lines. I have "Autodesk Product Design Suite premium 2013". Is this product sopposed to have the various content center hose ends and fittings and I just did not install them? Thanks. Phil
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't mean to keep talking to myself, but what started all this was (and is) my inability to make a point at the intersection of a work axis and work plane while in 3d sketch. If I knew how to do that I think I'd be all set. Can anyone help me do that? Thanks. Phil
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should have Content Center installed.
As for the point / work axis / plane intersection, how are you starting the run?
Are you clicking on 3D Sketch, or are you using the Routed Systems - New Route tool to create the 3D sketch??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In your original post you started out by stating you just switched from 2011 to 2013.
Did this technique work for you in 2011?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I found the problem. When I added point to my ribbon I used "point" not "work point". Everyting is fine now. Thank you for your help. Phil
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
