• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    gstaver45331
    Accepted Solution
    3d Grips missing
    140 Views, 4 Replies
    01-02-2013 11:17 AM
    I have a customer who has a Microsoft Windows Small Business Server 2011 setup. The are using Inventor 2012. All of the projects are stored on a share on this server. All of the workstations are Windows 7 x64 and are joined to the domain. Everything works fine except they cannot access the 3D Grips while logged in as a domain user. If the log into their workstation as a local user rather than a domain user then the 3d Grips are available. How do I make it so that the 3D Grips are available while logged in as a domain user?
    Please use plain text.
    Member
    gstaver45331
    Re: 3d Grips missing
    01-02-2013 11:19 AM in reply to: gstaver45331
    I should add that each domain user has local admin rights to their own pc.
    *Pro
    01-03-2013 04:23 AM in reply to: gstaver45331
    It might be as simple as Options settings, which are specific to the user login.  Check Application Options > Part tab > Enable 3D grips.
    On the other hand, why do they need 3D grips?  I have never used them except to play with when the functionality was first introduced.  I'm sure they're useful in certain kinds of design work, but they also can tempt a user to take shortcuts that create problems down the road.  But I'm willing to learn if someone can demonstrate their usefulness.
    *Expert Elite*
    01-03-2013 05:03 AM in reply to: sbixler
    sbixler wrote:
    On the other hand, why do they need 3D grips?  I have never used them ......
    That was my first reaction, "What are these 3D Grips you speak of?"
    OK, I would be concerned if there was some functionality that wasn't available in the scenario described - even if I never use it.
    Member
    gstaver45331
    01-09-2013 06:53 PM in reply to: gstaver45331
    The issue has been resolved. It was a security issue with some Inventor registry entries. Once I changed those then it started working. Thanks to everyone trying to help me.
