Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
3D sketch from text
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi
is it possible to create 3D sketch from text?
I need it for engraving as a toolpath and for drawings.
Emboss tool is more suitable for styling and visualisation.
Attached sample from Pro-E:
Re: 3D sketch from text
- Highlight
- Email to a Friend
Hi
nobody knows if Autodesk products can create a STEP file with a text transformed to wires?
Autodesk Product Design Suite Ultimate 2013 SP1.1
- Highlight
- Email to a Friend
In the model you can create a sketch and text is an option in the Draw panel. Make a text object, select the font and size you need and then use Extrude to "cut" the text into the object. Then use the Export command to export a STP file.
If I understand correctly this is what you want.
See attached
Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
8GB memory
Windows 7 64bit
- Highlight
- Email to a Friend
Yes, Extrude or Emboss is the simplest way. But plastic parts needs add a draft and it is a real pain in the.... For CNC machines is enough to use wires as a toolpath and the tool makes shape inclusive draft and fillets.
Does anybody from Autodesk know how to fix it?
