• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    3D sketch from text
    188 Views, 3 Replies
    09-12-2012 03:40 AM
    Hi
    is it possible to create 3D sketch from text?
    I need it for engraving as a toolpath and for drawings.
    Emboss tool is more suitable for styling and visualisation.
    Attached sample from Pro-E:
    Please use plain text.
    Active Member
    Re: 3D sketch from text
    11-16-2012 02:54 AM in reply to: klapec
    Hi
    nobody knows if Autodesk products can create a STEP file with a text transformed to wires?
    Autodesk Product Design Suite Ultimate 2013 SP1.1
    Distinguished Contributor
    11-16-2012 12:41 PM in reply to: klapec
    In the model you can create a sketch and text is an option in the Draw panel.  Make a text object, select the font and size you need and then use Extrude to "cut" the text into the object.  Then use the Export command to export a STP file.
    If I understand correctly this is what you want.
    See attached
    Stuart Kinzel
    Inventor 2013-64bit, HP EliteBook8740w Intel Core i5CPU 2.67 GHz
    8GB memory
    Windows 7 64bit
    Active Member
    11-18-2012 10:34 PM in reply to: SKinzel
    Yes, Extrude or Emboss is the simplest way. But plastic parts needs add a draft and it is a real pain in the.... For CNC machines is enough to use wires as a toolpath and the tool makes shape inclusive draft and fillets.
    Does anybody from Autodesk know how to fix it?
