• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    3D equation curve guide
    145 Views, 4 Replies
    03-19-2013 02:31 AM
    I am new to 3D equation curves but would like some basic training on them as I would like to start using them, does anyone know of a good starting point ? Thanks, greatly appreciated in advance
    Please use plain text.
    *Expert Elite*
    Re: 3D equation curve guide
    03-19-2013 04:18 AM in reply to: Anthony
    I posted a similar question yesterday - did you see this
    http://forums.autodesk.com/t5/Autodesk-Inventor/3d-sketch-equation-curve/td-p/3807450
    Also there are a couple of Help>Learning Tools>Tutorial examples and a search here on the forum turns up a couple of other user questions.
    I have some more I created since yesterday and will have my class coming up with some examples that I will post next week.
    Anthony
    03-19-2013 06:37 AM in reply to: JDMather
    This is most useful, thank you very much. I look forward to your posted examples. :smileyhappy:
    *Expert Elite*
    03-19-2013 07:58 AM in reply to: Anthony
    In earlier versions (before Equation Curves) there were a bunch of sample equations I think in Excel format and imported points into 2D and 3D sketches.  I think it was in the SDK folder, but not sure.
    In any case, I can't find them in 2013.
    Can someone with earlier release please post these examples?
    *Expert Elite*
    Curtis_Waguespack
    03-19-2013 08:06 AM in reply to: JDMather
    Hi  JDMather.
    Here are the 2010 versions of the files you mentioned.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
