• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    3D Surface Loft to 3D Surface
    164 Views, 4 Replies
    11-28-2012 05:22 AM
    I have been having some troubles with inventor trying to create a 0.5mm thick skin on a surface. I have tried everything and cant get it to work. In the picture i have the object and 2 seperate 3D surfaces that i need to join to create an object. the entior object is symetrical and has no imperfections how do i "loft" them? I have also attached the error messages.
    sammac13
    Please use plain text.
    *Expert Elite*
    Re: 3D Surface Loft to 3D Surface
    11-28-2012 05:35 AM in reply to: sammac13
    I don't see any surface bodies in the image.
    Can you attach the ipt file here?
    Member
    11-28-2012 05:38 AM in reply to: JDMather
    There you go.
    *Expert Elite*
    11-28-2012 07:21 AM in reply to: sammac13
    I am not exactly sure of what you are after - but check attached file.
    Member
    11-28-2012 01:56 PM in reply to: JDMather
    Yeah thats it thanks. how did you nominate the border of the design? so it only thickened in thet area.
