• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    HagenMueller
    3D-Polylines in Inventor Professional 2010
    115 Views, 2 Replies
    03-21-2012 07:01 AM
    Hi!
    following situation: 3D drawing in Inventor Professional 2010, consisting of lines and arches. How can I group respectively connect certain lines and arches so that these elements form one (3D-)polyline? Is that possible in general?
    Thanks for your advice!
    hagen
    Please use plain text.
    *Pro
    Re: 3D-Polylines in Inventor Professional 2010
    03-22-2012 03:57 AM in reply to: HagenMueller
    Language and terminology make it difficult to understand what you're asking.  Are the lines and arcs in a part file (.ipt)?  In more than one sketch?  It sounds as if you want to create a 3D sketch from existing 2D sketches-- if so, then create a new 3D sketch and Project Geometry.
    If I have misunderstood your question, please try again, perhaps with screen shots and the file(s) that you are working on.
    03-22-2012 04:07 AM in reply to: HagenMueller
    If you are coming from an AutoCAD background - you don't use/need polylines like in AutoCAD.
    Simply create 3D sketch using your 2D sketch as control with Bends.
    Attach your ipt  file here if you can't figure it out.
